[OpenLayers-Commits] r12428 - in sandbox/august/trunk:
	lib/OpenLayers/Format/OWSCommon lib/OpenLayers/Test util
    commits-20090109 at openlayers.org
    Thu Oct  6 18:43:03 EDT 2011
Author: augusttown
Date: 2011-10-06 15:43:01 -0700 (Thu, 06 Oct 2011)
New Revision: 12428
   sandbox/august/trunk/lib/OpenLayers/Format/OWSCommon/v1.js
   sandbox/august/trunk/lib/OpenLayers/Test/AgsOgcRegression.js
   sandbox/august/trunk/util/ags-proxy.jsp
Small change on Test/AgsOgcRegression.js;
Small change on util/ags-proxy.jsp.
Modified: sandbox/august/trunk/lib/OpenLayers/Format/OWSCommon/v1.js
--- sandbox/august/trunk/lib/OpenLayers/Format/OWSCommon/v1.js	2011-10-06 22:42:05 UTC (rev 12427)
+++ sandbox/august/trunk/lib/OpenLayers/Format/OWSCommon/v1.js	2011-10-06 22:43:01 UTC (rev 12428)
@@ -171,8 +171,13 @@
                 this.readChildNodes(node, dcp.http);
             "Get": function(node, http) {
-                http.get = this.getAttributeNS(node,
+            	http.get = this.getAttributeNS(node,
                     this.namespaces.xlink, "href");
+            	// deal with multiple get url, e.g. WMTS REST/KVP/SOAP etc.
+            	http.get = [];
+            	http.get.push(this.getAttributeNS(node, this.namespaces.xlink, "href"));
             "Post": function(node, http) {
                 http.post = this.getAttributeNS(node,
@@ -196,8 +201,8 @@
             "WGS84BoundingBox": function(node, obj) {
                 var boundingBox = {};
                 boundingBox.crs = node.getAttribute("crs");
-                if (obj.BoundingBox) {
-                    obj.BoundingBox.push(boundingBox);
+                if (obj.boundingBox) {
+                    obj.boundingBox.push(boundingBox);
                 } else {
                     obj.projection = boundingBox.crs;
                     boundingBox = obj;
Modified: sandbox/august/trunk/lib/OpenLayers/Test/AgsOgcRegression.js
--- sandbox/august/trunk/lib/OpenLayers/Test/AgsOgcRegression.js	2011-10-06 22:42:05 UTC (rev 12427)
+++ sandbox/august/trunk/lib/OpenLayers/Test/AgsOgcRegression.js	2011-10-06 22:43:01 UTC (rev 12428)
@@ -44,10 +44,10 @@
-	_run_get_mimeType: function(reqParams, refMimeType, t) {
-		var caller = this;
+	_run_get_mimeType: function(reqParams, refMimeType, t, optReqUrl) {
+		var caller = this;
 		OpenLayers.Request.GET({
-			url: this.url,
+			url: optReqUrl || this.url,
 			params: reqParams,
 			success: function(response) {
 				if(response.statusText=="OK" && response.status==200) {
Modified: sandbox/august/trunk/util/ags-proxy.jsp
--- sandbox/august/trunk/util/ags-proxy.jsp	2011-10-06 22:42:05 UTC (rev 12427)
+++ sandbox/august/trunk/util/ags-proxy.jsp	2011-10-06 22:43:01 UTC (rev 12428)
@@ -7,7 +7,8 @@
   //For ex. (non-secured server): "http://sampleserver1.arcgisonline.com/arcgis/rest/services"
   "http://sampleserver1.arcgisonline.com/arcgis/rest/services",
   "http://sampleserver2.arcgisonline.com/arcgis/rest/services",
-  "http://sazabi:8399/arcgis/rest/services"	 //NOTE - no comma after the last item
+  "http://ais3:6080/arcgis/rest/services",
+  "http://sazabiii:6080/arcgis/rest/services"	 //NOTE - no comma after the last item
More information about the Commits
