[OpenLayers-Dev] MouseToolbar on IE and Firefox
Antonio Volpicelli volpicelli at oato.inaf.it
Thu Apr 26 04:32:17 EDT 2007
Yes I am starting to use NavToolbar but can I render the controls on an
outside div ( not in the map div) ?
I am looking to the OpenLayers.Panel , but it seems not ready to be used
and has some problem with IE7.
If I run the panel.html page in the examples directory , it works fine
with firefox but doesn't display nothing with IE.
Schuyler Erle wrote:
> On Wed, 2007-04-25 at 00:38 +0200, Antonio wrote:
>> Hi ,
>> I am using ol 2.4.rc2 and I have this line in my code
>>              map.addControl(new OpenLayers.Control.MouseToolbar({'div':
>> $('toolbar'),direction:'orizontal'}));
>> This works fine with Firefox , doesn't work on IE ( I have IE 7, I
>> didn't try on IE 6).
>> The line
>> map.addControl(new OpenLayers.Control.MouseToolbar());
>> work with both.
> The MouseToolbar is deprecated. Try using the NavToolbar control
> instead.
More information about the Dev mailing list
