[OpenLayers-Dev] OpenLayers.Format.KML.write()
Damien Corpataux damien.corpataux at camptocamp.com
Tue Aug 14 10:16:32 EDT 2007
Hello,
I'd like to implement a bit of OpenLayers.Format.KML.write() method, and
enhance OpenLayers.Format.KML.read() to enabl.e Polygon node parsing...
Questions:
1/ Did you have any reason not to have implemented Polygon parsing at
once with Point and LineString? I thought it could be because of the
outerBoudaryIs node, which cannot be translated into OpenLayers.Geometry
object...? Or was it just laziness? :-)
2/ How do you see the namespaces for KML? My view is that one can parse
any KML as a 2.0, fetching Placemark nodes and digging into their
geometries, since this seems not to change over versions. Do you think
it's a good way of doing it?
Cheers,
Damien
Camptocamp SA
Damien Corpataux
PSE A
CH-1015 Lausanne
+41 21 619 10 22 (Direct)
+41 21 619 10 10 (Centrale)
+41 21 619 10 00 (Fax)
P Please consider the environment
Do you really need to print this email?
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070814/226445e8/attachment.html
More information about the Dev mailing list
