[OpenLayers-Dev] GML examples?
Christopher Schmidt
crschmidt at metacarta.com
Tue Aug 28 15:38:01 EDT 2007
On Tue, Aug 28, 2007 at 01:23:50PM -0400, Christopher Schmidt wrote:
> On Tue, Aug 28, 2007 at 10:42:07AM -0500, John Cole wrote:
> > I suppose the correct fix would be to run the output form PostGIS through a
> > stylesheet to fix this, so I don't think OL should have to support a bad
> > schema.
> > I just selected a zip code from MsSqlSpatial and the results are below. It
> > has the same outerBoundaryIs tag.
> The problem is that PostGIS doesn't use "outerBoundaryIs" -- it uses
> "OuterBoundaryIs".
And in researching this, I found that our wonderful OpenLayers
contributor Eric Lemoine already sent a patch to fix this 5 months ago:
http://postgis.refractions.net/pipermail/postgis-devel/2007-March/002507.html
I've followed up to this asking what the current status is.
http://postgis.refractions.net/pipermail/postgis-devel/2007-August/002753.html
In the meantime, I have no plans to make our GML layer support the
particularly broken flavor of GML polygons that PostGIS spits out.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
