[OpenLayers-Dev] A generic button class:
    Paul Spencer
    pspencer at dmsolutions.ca
    Tue Jul 31 07:41:18 EDT 2007
On 30-Jul-07, at 4:50 PM, Jeff Dege wrote:
>> From: dev-bounces at openlayers.org
>> [mailto:dev-bounces at openlayers.org] On Behalf Of Tim Schaub
>> Sent: Monday, July 30, 2007 2:50 PM
>> Cc: dev at openlayers.org
>> Subject: Re: [OpenLayers-Dev] A generic button class:
>> Finally, for documentation sake alone, it makes sense to define an
> empty
>> onClick method on the prototype (onClick: function() {}). Document
> that
>> and have your trigger method always call it.
> If we do that, then the trigger function no longer seems meaningful.
> Instead of my:
>     onClick: null,
>     type: OpenLayers.Control.TYPE_BUTTON,
>     trigger: function() {
>         if (this.onClick)
>            this.onClick();
> We'd have:
>     onClick: function() {},
>         this.onClick();
> In which case, we could just as easily leave out the onClick()
> function,
> altogether, and instead of using the class thus:
>     panel.addControls([nav,
>         new OpenLayers.Control.Button(
>           {'displayClass': 'MyButton', 'onClick': myFunction});
> do this:
>     panel.addControls(new OpenLayers.Control.GenericButton(
>         {'displayClass': 'MyButton', 'trigger': myFunction});
> And from that, we could skip the Button control entirely:
>     panel.addControls(new OpenLayers.Control({type:
> At which point, things are simple enough that I'm not at all sure that
> we gain anything by defining a separate Button class.
Jeff,
are you going to modify your own code to stop using the Button
control and use the last case, or do you still see it as being
desirable to have a separate 'Button' control?  Given that OL is
usually fairly semantically verbose already, I don't see a real
problem with having a distinct Button control.
Paul
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
More information about the Dev
