[OpenLayers-Dev] error message
Christopher Schmidt crschmidt at metacarta.com
Fri May 4 07:45:51 EDT 2007
On Fri, May 04, 2007 at 01:02:50PM +0300, E.Stefanakis wrote:
> Running the http://svn.openlayers.org/trunk/openlayers/examples/openmnnd.html
> I get the following error message:
> "Unhandled request return not found"
> Any suggestion on what causes this message ?
404 coming from the URL that the browser is attempting to visit.
Usually, this means that the ProxyHost you have set up is wrong. Check
the XMLHttpRequests with Firebug if you want to do more debugging.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
