[OpenLayers-Dev] popups.html example
Les Szklanny lszklanny at where2getit.com
Fri May 4 08:46:18 EDT 2007
Christopher Schmidt wrote:
> On Mon, Apr 09, 2007 at 08:12:46AM -0500, Les Szklanny wrote:
>> BTW the 2.4 RC1 examples don't display the map in Safari, so I think
>> there's a problem with this browser.
> Safari doesn't like the non-single file version of OpenLayers -- there
> doesn't seem to be a way to delay execution of the script long enough to
> let everying load. I've not yet had problems with Safari opening
> applications using the single file build, which is what we recommend for
> production use.
> Regards,
I just tried RC3 on Safari 1.3.2... multiple and single file
version...it will not display the map... so there's a problem.
Regards,
Les Szklanny
More information about the Dev mailing list
