[OpenLayers-Dev] Trying to make a feature editing demo
Stephen Woodbridge woodbri at swoodbridge.com
Mon Feb 25 00:01:04 EST 2008
And have some success, some issues.
http://imaptools.com/~woodbri/edit/index.php?extent=-129,19+-60,60
I created some additional icons, and added them to theme/default/img/
and updated theme/default/styles.css, but I can not get the icons to
show up.
I have been able to hack a trivial save-wfs.php that will handle inserts
into a postgres database, so you can add features and they persist. Next
I need to handle modify and delete. I have spent all weekend working on
this, mostly I have been looking at examples, read the docs and reading
the code.
Also there is one more thing I can not figure out how to do and that is
to add a save button to the control panel, instead of having it as a
link under the map. The control panel will have icons for:
[save][insert][modify][delete][navigate]
if I can figure it all out. I'm only working with polygons at the moment.
Most of this is code borrowed from examples and posts to the list and my
own naive attempts to cobble this together. I would gladly take any
input if someone would like to look over what I have so far. I'm happy
to contribute that icons, php, and the code back to the examples page if
this would be worth while.
Thanks for any help and guidance you might be willing to offer. Code
snippets gladly accepted ;)
-Steve W
More information about the Dev mailing list
