[OpenLayers-Dev] dragstart, drag and dragend events
Pierre GIRAUD bluecarto at gmail.com
Mon Feb 25 04:56:21 EST 2008
Once more, I'm stuck with this issue.
This time I would like to register for 'dragstart' and 'dragend' in
the new popup class to set the contentDiv overflow to 'hidden'
temporarily when the user drags the map.
However, the 'drag*' events are never triggered.
I cannot use 'move*' events because they ain't triggered when the map
is manually dragged.
Any idea ?
I'm convinced that we should :
 - trigger those events,
 - or at least, remove the drag* events from the list of available
events to listen to (wrong doc).
Regards,
Pierre
On Thu, Jun 14, 2007 at 8:17 AM, Pierre GIRAUD <bluecarto at gmail.com> wrote:
> On 6/12/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> > On Tue, Jun 12, 2007 at 05:31:54PM +0200, Pierre GIRAUD wrote:
>  > > I cannot get any event register working with "dragstart" or "dragend"
>  > > using something like following :
>  > > map.events.register("dragstart", map, function(evt) {
>  > >                    console.log("drag end");
>  > I think you're trying to detect something that isn't going to happen --
>  > dragstart is related to dragging the element. If you're trying to
>  > determine when someone starts dragging the map, you might want movestart
>  > or moveend... What are you trying to do?
>  I was just having a test with all the map available EVENT_TYPES.
>  EVENT_TYPES: [
>         "addlayer", "removelayer", "changelayer", "movestart", "move",
>         "moveend", "zoomend", "popupopen", "popupclose",
>         "addmarker", "removemarker", "clearmarkers", "mouseover",
>         "mouseout", "mousemove", "dragstart", "drag", "dragend",
>         "changebaselayer"],
>  I can't figure out what are the dragX events for.
>  Though, I'm ok that the moveX events are sufficient for several cases.
>  Regards
More information about the Dev mailing list
