[OpenLayers-Dev] Map id
Christopher Schmidt crschmidt at metacarta.com
Wed Feb 27 07:42:39 EST 2008
On Wed, Feb 27, 2008 at 08:23:12AM +0100, Nils Weinander wrote:
> Fr?d?ric Junod:
>  > This is not not a good idea to control the CSS by using the id
>  > of the html elements: they are generated by a "random" algorithm
>  > and can change. You have guarantees that the id will always be
>  > "OpenLayers.Map_2.
>  > Your graphics designer should use the CSS class instead.
> This is indeed the case, but
> Christopher Schmidt:
>  > And if (as is likely the case) the CSS class isn't set on the
>  > element in question, one should be set.
> This is the reason for using the Id. The ZoomBar (the "ladder")
> and the ZoomBar slider are represented by classless <div>-s with
> a background image.
Right. But this is the bug, not the use of a non-useful ID :) (As fred
pointed out.)
Classes should be named things like .olControlPanZoomBarSlider and so on
in order to fit with OL Conventions.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
