[OpenLayers-Dev] "Action element" design choice
Nils Weinander nils.weinander at curalia.se
Wed Feb 27 04:46:31 EST 2008
Christopher Schmidt:
 > You can set title + alt on image tags to get teh same effect in both
 > browsers, where a small tooltip is displayed when hovering over an
 > element.
That should suffice, I think, but we still need the
elements to be reachable by tabbing.
 > I'm +0 on modifying the buttons to be anchors in addition to images,
 > if it's done in such a way that it doesn't change the current
 > behavior.
That is of course a condition.
Tim Schaub:
 > Yeah, see if you can get the effect you want by setting title/alt
 > attributes.  In general, I'm I'm -0 on changing to anchors, since href
 > gets followed whenever there is an error in the onclick code (not that
 > big a deal here, just an annoyance, even for #).
I'll explain the background for this. We are developing a
map-centric web application for a swedish government agency
who have to follow strict accessibility guidelines. I realize
that using an interactive map with keyboard only is probably
not what you want to do, but it is one requirement. Thus our
need for <a href>-s.
I suggest a new top-level flag, e.g.
OpenLayers.STRICT_ACCESSIBILITY = true;
to turn on anchors. We will probably need to do this regardless,
but would such a solution be an acceptable addition if we submit
it?
Nils Weinander  |  Systems Designer
Phone +46 (0)8 410 064 56
Mobile +46 (0)70 978 28 37
Curalia AB  |  www.curalia.se
Västmannagatan 15, 111 24 Stockholm, Sweden
More information about the Dev mailing list
