[OpenLayers-Dev] New Zealand Map Grid in OpenLayer and Proj4js
Mike Adair madair at dmsolutions.ca
Thu Jul 10 09:07:58 EDT 2008
Cool! We're still in the process of moving the project infrastructure
for proj4js but in the meantime you can enter a ticket and patch in the
Trac system at: http://trac.osgeo.org/proj4js/
And eventually it should make it's way into the code base.
Mike
Stephen Irons wrote:
> I have implemented a Proj4js transformation for New Zealand Map Grid
> (NZMG) co-ordinates (EPSG:27200). spatial-reference.org
> <http://spatial-reference.org> gives a description of the
> transformation, but the '+proj=nzmg' was not available in the current
> version in the repository. This projection is not related to any of
> the existing types, so I implemented it.
> I would like to contribute this code to Proj4js. However, it is not
> obvious how to submit this code to the project. Can anyone here point
> me to the right place?
> Stephen Irons
> Background
> New Zealand Map Grid (NZMG) is a projection used to convert latitude
> and longitude to easting and northing coordinates in metres. It was
> designed to minimize the scale error over the land area of New Zealand
> and cannot be used elsewhere.
> The New Zealand govnernment survey agency, LINZ (Land Information New
> Zealand) has published two series of maps covering the mainland areas
> of New Zealand.
>     * 262-series is 1:250000
>     * 260-series is 1:50000
> These maps are available in printed form and are currently the only
> large-scale maps of New Zealand widely available to the general
> public. Vector data is also available.
> Various commercial concerns have scanned these maps, or generated
> tiles from the vector data, and released products using these tiles. I
> have one of these products and want to use the tiles with OpenLayers.
> New Zealand Map Grid was designed by Dr W. I. Reilly in 1973. Its
> official specification is published as /New Zealand Map Grid/,
> Department of Lands and Survey Technical Circular 1973/32. A scanned
> image of the publication is available at
> http://www.linz.govt.nz/docs/miscellaneous/nz-map-definition.pdf
> It is also described in /Conversion between Latitude and Longitude and
> New Zealand Map Grid/, OSG Technical Report 4.1, 1998. This document
> is available at http://www.linz.govt.nz/docs/miscellaneous/nzmg.pdf
> NZMG is given EPSG code EPSG:27200. It is defined at
> http://spatialreference.org/ref/epsg/27200/proj4/ as
>     * "+proj=nzmg +lat_0=-41 +lon_0=173 +x_0=2510000 +y_0=6023150
>       +ellps=intl +datum=nzgd49 +units=m +no_defs"
> Now, most of this is known to Proj4js code. However, the projections
> 'nzmg' is not know, and needs to be implemented.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
