[OpenLayers-Dev] New Zealand Map Grid in OpenLayer and Proj4js
Stephen Irons stephen.irons at clear.net.nz
Mon Jul 14 14:47:23 EDT 2008
Thank you. I saw the proj4js Trac website, but there were no tickets
entered, so I assumed it was not in use.
There is now one ticket open...hope someone else finds the NZMG
transformation useful.
Stephen
On Thu, 2008-07-10 at 09:07 -0400, Mike Adair wrote:
> Cool! We're still in the process of moving the project infrastructure
> for proj4js but in the meantime you can enter a ticket and patch in the
> Trac system at: http://trac.osgeo.org/proj4js/
> And eventually it should make it's way into the code base.
> Mike
> Stephen Irons wrote:
> > I have implemented a Proj4js transformation for New Zealand Map Grid
> > (NZMG) co-ordinates (EPSG:27200). spatial-reference.org
> > <http://spatial-reference.org> gives a description of the
> > transformation, but the '+proj=nzmg' was not available in the current
> > version in the repository. This projection is not related to any of
> > the existing types, so I implemented it.
> > I would like to contribute this code to Proj4js. However, it is not
> > obvious how to submit this code to the project. Can anyone here point
> > me to the right place?
> > Stephen Irons
> > Background
> > New Zealand Map Grid (NZMG) is a projection used to convert latitude
> > and longitude to easting and northing coordinates in metres. It was
> > designed to minimize the scale error over the land area of New Zealand
> > and cannot be used elsewhere.
> > The New Zealand govnernment survey agency, LINZ (Land Information New
> > Zealand) has published two series of maps covering the mainland areas
> > of New Zealand.
> >     * 262-series is 1:250000
> >     * 260-series is 1:50000
> > These maps are available in printed form and are currently the only
> > large-scale maps of New Zealand widely available to the general
> > public. Vector data is also available.
> > Various commercial concerns have scanned these maps, or generated
> > tiles from the vector data, and released products using these tiles. I
> > have one of these products and want to use the tiles with OpenLayers.
> > New Zealand Map Grid was designed by Dr W. I. Reilly in 1973. Its
> > official specification is published as /New Zealand Map Grid/,
> > Department of Lands and Survey Technical Circular 1973/32. A scanned
> > image of the publication is available at
> > http://www.linz.govt.nz/docs/miscellaneous/nz-map-definition.pdf
> > It is also described in /Conversion between Latitude and Longitude and
> > New Zealand Map Grid/, OSG Technical Report 4.1, 1998. This document
> > is available at http://www.linz.govt.nz/docs/miscellaneous/nzmg.pdf
> > NZMG is given EPSG code EPSG:27200. It is defined at
> > http://spatialreference.org/ref/epsg/27200/proj4/ as
> >     * "+proj=nzmg +lat_0=-41 +lon_0=173 +x_0=2510000 +y_0=6023150
> >       +ellps=intl +datum=nzgd49 +units=m +no_defs"
> > Now, most of this is known to Proj4js code. However, the projections
> > 'nzmg' is not know, and needs to be implemented.
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20080715/841ce92c/attachment.html
More information about the Dev mailing list
