[OpenLayers-Dev] Map event confusion
Tim Schaub tschaub at opengeo.org
Fri Mar 26 17:31:28 EDT 2010
Stephen Woodbridge wrote:
> Tim, et al,
> This may a question based on my ignorance, but why isn't the
> EVENTS_TYPES array dynamically appended to when someone adds an event
> listener vi map.events.on() or registerListener() or whatever registeres
> event listeners.
> Then the predefined list of events would only need to include those
> events the OL depends on being there.
We could rewrite Events.js to allow listeners to be registered for any
named event.  And I think this could be done without negative
side-effect (dispensing entirely with EVENT_TYPES arrays).
Tim
> -Steve W
> Tim Schaub wrote:
>> I'm in favor of removing this cruft as well.
>> To be clear, here are things that "work" currently:
>>      // myapp.js
>>      map.events.on({
>>          popupopen: myPopupOpenListener,
>>          // and the rest
>>      var openPopup = function() {
>>          var pop = createPopup();  // defined elsewhere
>>          pop.show();
>>          map.events.triggerEvent("popupopen", {popup: pop});
>> Currently, if application code makes use of the events listed below,
>> the corresponding event listeners get called appropriately.
>> After removing these entries from the EVENT_TYPES array, these
>> listeners will not get called.
>> Again, I'm fine with this.  Just wanted to be clear that we are
>> changing the behavior of any applications that might be using these
>> named events (perhaps none).
>> Tim
>> Marc Jansen wrote:
>>> Hi all,
>>> so do you all think I should open up a ticket with milestone 2.10
>>> including a patch that does
>>>     * leave the events in the EVENT_TYPES array as they currently are
>>>     * but changes the documentation to not reference the events
>>>           o addmarker,
>>>           o removemarker,
>>>           o clearmarkers,
>>>           o dragstart,
>>>           o dragend,
>>>           o drag,
>>>           o popupopen,
>>>           o popupclose anymore?
>>>     * should I add yet another ticket to remove the unneeded events
>>> in 3.0?
>>> What do you think? I am willing to provide a patch for the above ticket.
>>> Regards and thanks for your opinions,
>>> Marc
>>> Stephen Woodbridge schrieb:
>>>> Christopher Schmidt wrote:
>>>>> On Thu, Mar 25, 2010 at 03:32:36PM -0600, Tim Schaub wrote:
>>>>>> Marc Jansen wrote:
>>>>>>> Hi devs,
>>>>>>> I am rather confused about the documentation about map-events. Is
>>>>>>> it right that
>>>>>>>     * addmarker,
>>>>>>>     * removemarker,
>>>>>>>     * clearmarkers,
>>>>>>>     * dragstart,
>>>>>>>     * dragend,
>>>>>>>     * drag
>>>>>>> are defined but never get triggered?
>>>>>>> If so, they should IMHO be removed from the EVENT_TYPES-array and
>>>>>>> the documentation for that.
>>>>>> The problem with removing things from the EVENT_TYPES array is
>>>>>> that there could be applications that have subscribers for them
>>>>>> and use map.events to publish.
>>>>>> If we remove those entries, those applications break.
>>>>>> I know this is silly.  You are right to point out that there is
>>>>>> little sense and lots of confusion in having them.
>>>>>> Our safest bet is to mark them as unused and remove them in 3.0.
>>>>>> If others think the caution is not needed, I wouldn't be opposed
>>>>>> to removing them.
>>>>> In general, I'm supportive of any changes that make things simpler
>>>>> which
>>>>> means that applications that did not throw errorrs in earlier
>>>>> releases will
>>>>> continue to not throw errors in future releases.
>>>>> In this particular case, it's hard to imagine that someone has written
>>>>> code that specifically registers for an event that doesn't do
>>>>> anything.
>>>>> With sufficient documentation, I'd be willing to change the code to
>>>>> not
>>>>> have those events. However,  since events (unlike methods) are not
>>>>> actually
>>>>> in existence in the Natural Docs except if they're documented, I think
>>>>> it would be equally successful -- for anyone who isn't actually
>>>>> digging
>>>>> into the code itself, a fact that describes more and more of our
>>>>> users --
>>>>> to just not document those events. At that point, the events simply
>>>>> 'disappear' from the docs completely without any other work on our
>>>>> part.
>>>>> -- Chris
>>>> Chris, et al,
>>>> I can appreciate this sentiment, I think there are a lot of "casual"
>>>> users that will not dig into the code and in those cases, if it is
>>>> not in the docs then the problem does indeed go away. But there are
>>>> a small but healthy number of "coders" who are trying to do more
>>>> with OpenLayers like Marc, myself and others I'm sure that do dig
>>>> into the code and spend a lot of time chasing our tails, aka:
>>>> learning? :) because we try something like an event that never gets
>>>> triggered and then scratch our heads for a while trying to figure
>>>> out why. We eventually do figure it out or ask and get help. I would
>>>> like to see doc that better explains what events exist and what gets
>>>> passed to them. I have also noticed that there is a trend to move
>>>> away from callbacks, which were somewhat better documented, in favor
>>>> of using events (or maybe I'm mistaken) and some objects say
>>>> register for such and such event to get notified when something
>>>> happens, but there is no additional information as to what is passed
>>>> to the event, etc.
>>>> Regardless, I'm loving OL and continued to be impressed by how much
>>>> is built into OL and how easy OL is to extend once I can get my head
>>>> to think about the problem in in the right way.
>>>> Thanks all and best regards,
>>>>    -Steve
>>>>>> Tim
>>>>>>> Please ignore the mail if I missed something fundamental (but
>>>>>>> please enlighten me where these events are triggered)
>>>>>>> Regards,
>>>>>>> Marc
>>>>>>> _______________________________________________
>>>>>>> Dev mailing list
>>>>>>> Dev at openlayers.org
>>>>>>> http://openlayers.org/mailman/listinfo/dev
>>>>>> Tim Schaub
>>>>>> OpenGeo - http://opengeo.org
>>>>>> Expert service straight from the developers.
>>>>>> Dev mailing list
>>>> Dev mailing list
>>> Dev mailing list
Tim Schaub
More information about the Dev mailing list
