[OpenLayers-Dev] Map event confusion
Tim Schaub tschaub at opengeo.org
Fri Mar 26 18:05:04 EDT 2010
Tim Schaub wrote:
> Stephen Woodbridge wrote:
>> Tim, et al,
>> This may a question based on my ignorance, but why isn't the
>> EVENTS_TYPES array dynamically appended to when someone adds an event
>> listener vi map.events.on() or registerListener() or whatever registeres
>> event listeners.
>> Then the predefined list of events would only need to include those
>> events the OL depends on being there.
> We could rewrite Events.js to allow listeners to be registered for any
> named event.  And I think this could be done without negative
> side-effect (dispensing entirely with EVENT_TYPES arrays).
See patch for http://trac.openlayers.org/ticket/2555
> Tim
>> -Steve W
>> Tim Schaub wrote:
>>> I'm in favor of removing this cruft as well.
>>> To be clear, here are things that "work" currently:
>>>      // myapp.js
>>>      map.events.on({
>>>          popupopen: myPopupOpenListener,
>>>          // and the rest
>>>      var openPopup = function() {
>>>          var pop = createPopup();  // defined elsewhere
>>>          pop.show();
>>>          map.events.triggerEvent("popupopen", {popup: pop});
>>> Currently, if application code makes use of the events listed below,
>>> the corresponding event listeners get called appropriately.
>>> After removing these entries from the EVENT_TYPES array, these
>>> listeners will not get called.
>>> Again, I'm fine with this.  Just wanted to be clear that we are
>>> changing the behavior of any applications that might be using these
>>> named events (perhaps none).
>>> Tim
>>> Marc Jansen wrote:
>>>> Hi all,
>>>> so do you all think I should open up a ticket with milestone 2.10
>>>> including a patch that does
>>>>     * leave the events in the EVENT_TYPES array as they currently are
>>>>     * but changes the documentation to not reference the events
>>>>           o addmarker,
>>>>           o removemarker,
>>>>           o clearmarkers,
>>>>           o dragstart,
>>>>           o dragend,
>>>>           o drag,
>>>>           o popupopen,
>>>>           o popupclose anymore?
>>>>     * should I add yet another ticket to remove the unneeded events
>>>> in 3.0?
>>>> What do you think? I am willing to provide a patch for the above ticket.
>>>> Regards and thanks for your opinions,
>>>> Marc
>>>> Stephen Woodbridge schrieb:
>>>>> Christopher Schmidt wrote:
>>>>>> On Thu, Mar 25, 2010 at 03:32:36PM -0600, Tim Schaub wrote:
>>>>>>> Marc Jansen wrote:
>>>>>>>> Hi devs,
>>>>>>>> I am rather confused about the documentation about map-events. Is
>>>>>>>> it right that
>>>>>>>>     * addmarker,
>>>>>>>>     * removemarker,
>>>>>>>>     * clearmarkers,
>>>>>>>>     * dragstart,
>>>>>>>>     * dragend,
>>>>>>>>     * drag
>>>>>>>> are defined but never get triggered?
>>>>>>>> If so, they should IMHO be removed from the EVENT_TYPES-array and
>>>>>>>> the documentation for that.
>>>>>>> The problem with removing things from the EVENT_TYPES array is
>>>>>>> that there could be applications that have subscribers for them
>>>>>>> and use map.events to publish.
>>>>>>> If we remove those entries, those applications break.
>>>>>>> I know this is silly.  You are right to point out that there is
>>>>>>> little sense and lots of confusion in having them.
>>>>>>> Our safest bet is to mark them as unused and remove them in 3.0.
>>>>>>> If others think the caution is not needed, I wouldn't be opposed
>>>>>>> to removing them.
>>>>>> In general, I'm supportive of any changes that make things simpler
>>>>>> which
>>>>>> means that applications that did not throw errorrs in earlier
>>>>>> releases will
>>>>>> continue to not throw errors in future releases.
>>>>>> In this particular case, it's hard to imagine that someone has written
>>>>>> code that specifically registers for an event that doesn't do
>>>>>> anything.
>>>>>> With sufficient documentation, I'd be willing to change the code to
>>>>>> not
>>>>>> have those events. However,  since events (unlike methods) are not
>>>>>> actually
>>>>>> in existence in the Natural Docs except if they're documented, I think
>>>>>> it would be equally successful -- for anyone who isn't actually
>>>>>> digging
>>>>>> into the code itself, a fact that describes more and more of our
>>>>>> users --
>>>>>> to just not document those events. At that point, the events simply
>>>>>> 'disappear' from the docs completely without any other work on our
>>>>>> part.
>>>>>> -- Chris
>>>>> Chris, et al,
>>>>> I can appreciate this sentiment, I think there are a lot of "casual"
>>>>> users that will not dig into the code and in those cases, if it is
>>>>> not in the docs then the problem does indeed go away. But there are
>>>>> a small but healthy number of "coders" who are trying to do more
>>>>> with OpenLayers like Marc, myself and others I'm sure that do dig
>>>>> into the code and spend a lot of time chasing our tails, aka:
>>>>> learning? :) because we try something like an event that never gets
>>>>> triggered and then scratch our heads for a while trying to figure
>>>>> out why. We eventually do figure it out or ask and get help. I would
>>>>> like to see doc that better explains what events exist and what gets
>>>>> passed to them. I have also noticed that there is a trend to move
>>>>> away from callbacks, which were somewhat better documented, in favor
>>>>> of using events (or maybe I'm mistaken) and some objects say
>>>>> register for such and such event to get notified when something
>>>>> happens, but there is no additional information as to what is passed
>>>>> to the event, etc.
>>>>> Regardless, I'm loving OL and continued to be impressed by how much
>>>>> is built into OL and how easy OL is to extend once I can get my head
>>>>> to think about the problem in in the right way.
>>>>> Thanks all and best regards,
>>>>>    -Steve
>>>>>>> Tim
>>>>>>>> Please ignore the mail if I missed something fundamental (but
>>>>>>>> please enlighten me where these events are triggered)
>>>>>>>> Regards,
>>>>>>>> Marc
>>>>>>>> _______________________________________________
>>>>>>>> Dev mailing list
>>>>>>>> Dev at openlayers.org
>>>>>>>> http://openlayers.org/mailman/listinfo/dev
>>>>>>> Tim Schaub
>>>>>>> OpenGeo - http://opengeo.org
>>>>>>> Expert service straight from the developers.
>>>>>>> Dev mailing list
>>>>> Dev mailing list
>>>> Dev mailing list
Tim Schaub
More information about the Dev mailing list
