[OpenLayers-Dev] Working on 3.0 git...
Eric Lemoine eric.lemoine at camptocamp.com
Tue Oct 12 14:44:39 EDT 2010
On Tue, Oct 12, 2010 at 8:02 PM, Alexandre Dube <adube at mapgears.com> wrote:
> Hi devs,
Hi
I'm not a github expert, but I'll try to answer your questions, hoping
that others will correct my mistakes.
>  I started working on 3.0 tickets and got used with git for the first time.
>  I have a couple of questions I'd like to ask, but first a small overview of
> the situation : so far, I adopted a "one branch per ticket" strategy.  So
> far, I did two (#522 and #1275) , i.e. I commited to my fork the fixes
> needed for each one in their specific branch.  I was able to get the master
> "upstream" repo to update mine as well.
> === what should I do now ? ===
>  Now, I'm just wondering what I should do with the work I did.  Should I
> leave a note on the trac ticket even though it's not to be commited in svn ?
>  Should I do nothing since the graph already demonstrate pretty much every
> work done by everyone ?
Let's say you're done with #1275. You can merge your "1275" branch
into your master, and push this to your origin's master (your github
repo). Once done you can do a pull request, for a core developer to
pull your commits in the master of openlayers/openlayers.
> === where is my 522 branch ? ===
>  About the github network graph [1], I don't see yet the last branch with
> its commit I just did.  Is there supposed to be any delay ?
Maybe the branch exists in your local repository but not in your
github repository. To create the branch in your github repository I
think you can just push your commits to this branch as it existed:
$ git push origin 522:522
Hope it helps,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev mailing list
