[OpenLayers-Dev] Re: when moving/dragging a feature the moveend event has zoomChanged set to true.
MostlyBaldEagle MostlyBaldEagle at shaw.ca
Thu Sep 2 13:27:08 EDT 2010
Yes, see attached html file.
3 actions
move map -> zoomChanged not set
zoom in -> zoomChanged is set (correct behavior)
drag marker -> zoomChanged is set (bug ?)
http://osgeo-org.1803224.n2.nabble.com/file/n5492049/ZoomEventBug.htm
ZoomEventBug.htm
View this message in context: http://osgeo-org.1803224.n2.nabble.com/when-moving-dragging-a-feature-the-moveend-event-has-zoomChanged-set-to-true-tp5489240p5492049.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
