[OpenLayers-Dev] Re: Problems with freehand drawing in 2.11
Kenny Lam khl1392 at gmail.com
Wed Aug 10 11:32:07 EDT 2011
Hi Xavier,
Right now, I've done testing on Android 2.2 and 2.3 for both the original
problem and the patch fix. I encountered the original problem on  iOS 4, but
haven't since tried the patch yet.
Thanks so much for your help so far though!
On Tue, Aug 9, 2011 at 1:00 PM, Kenny Lam <khl1392 at gmail.com> wrote:
> The patch
> http://trac.osgeo.org/openlayers/attachment/ticket/3456/touch-freehand-3456.patch
> for freehand drawing on mobile devices works!
> However, the shape isn't visible while it's being drawn, only after you've
> completed the drawing (i.e. lifted your finger).
> Thanks again.
> On Wed, Aug 3, 2011 at 3:41 PM, Kenny Lam <khl1392 at gmail.com> wrote:
>> Hi,
>> I'm having problems with any sorts of freehand drawing on a mobile
>> platform with 2.11. I haven't had any success with a potential solution, and
>> it either passes the motion into the browser window itself and pans the
>> browser app or does nothing, but clearly tries to keep up with the tapped
>> position. I'm using the handlers from polygon and path, and neither seems to
>> work right. Any solutions?
>> Thanks.
Kenny H. Lam
Massachusetts Institute of Technology
Department of Physics | Class of 2013
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110810/69ff6b86/attachment.html
More information about the Dev mailing list
