[OpenLayers-Dev] Re: More undefined variables on OpenLayers!
christopher.schmidt at nokia.com christopher.schmidt at nokia.com
Tue Mar 8 09:21:17 EST 2011
Xavier,
The first step for closure integration was to integrate it as a build tool.
I am supportive of other developers who are interested taking on the integration
(and more importantly, *documentation*) of how to use Closure Compiler as a
tool for finding warnings -- in the same way that developers currently use
jslint to find errors and mistakes.
At this point, I do not have the time to invest in understanding closure enough
to integrate your changes in a way that I can understand how to use them, and
your patches did not make it clear to me how I would use closure to find these
warnings. (As I said in comments on the ticket, I think that the work you've
done is interesting, but I just don't understand it.)
If other developers are interested in taking it on, they're welcome to, obviously.
I just knew that I wasn't going to invest in it, and no one else expressed a
strong interest at the time, so I bumped it.
-- Chris
On Mar 8, 2011, at 3:58 AM, ext Xavier Mamano (jorix) wrote:
> Hi Tim Schaub,
> I think it would be interesting if any developer could easily use the
> Closure Compiler in this way as part of the tests.
> For this reason I investigated the use of Closure and wrote #2972 and later
> http://trac.osgeo.org/openlayers/ticket/3008.
> (the current implementation of Closure in OL not allow this use, and should
> be reviewed: does not work on Windows see #3158)
> Now #3008 is Milestone Future. I think it would be interesting to implement
> some of its parts in 2.11
> Regards,
> Xavier Mamano
> Tim Schaub wrote:
>> On 3/7/11 2:29 PM, Xavier Mamano (jorix) wrote:
>>> Hi,
>>> Using Closure Compiler is possible to have a report of all undefined
>>> variables.
>>> Now this is the result:
>>> ..\lib\OpenLayers\Layer\Grid.js:704: ERROR - variable tlViewPort is
>>> undefined
>>> tlViewPort = tlLayer.add(offsetX, offsetY);
>> http://trac.osgeo.org/openlayers/changeset/11663/
>>> ..\lib\OpenLayers\Map.js:1692: ERROR - variable yRestriction is undefined
>>> var xRestriction = yRestriction = 0;
>> http://trac.osgeo.org/openlayers/changeset/11664/
>>> ..\lib\OpenLayers\Renderer\SVG2.js:655: ERROR - variable component is
>>> undefined
>>> component = components[i];
>> http://trac.osgeo.org/openlayers/changeset/11665/
>>> 3 error(s), 26 warning(s)
>> Thanks for the vigilance.
>> Tim
>>> (now is not possible get this report using "build.py -c closure")
>>> Xavier Mamano
>>> View this message in context:
>>> http://osgeo-org.1803224.n2.nabble.com/More-undefined-variables-on-OpenLayers-tp6099332p6099332.html
>>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>>> Dev mailing list
>>> Dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>> Tim Schaub
>> OpenGeo - http://opengeo.org
>> Expert service straight from the developers.
>> Dev mailing list
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/More-undefined-variables-on-OpenLayers-tp6099332p6115872.html
> Dev mailing list
More information about the Dev mailing list
