[OpenLayers-Dev] #1633: remove dependency on popup and marker from vector feature
Bart van den Eijnden bartvde at osgis.nl
Wed Mar 30 06:37:19 EDT 2011
Hi Frederic,
agreed, that should be sufficient.
Best regards,
Bart
Looking for flexible support on OpenLayers or GeoExt? Please check out http://www.osgis.nl/support.html
OSGIS
bartvde at osgis.nl
On Mar 30, 2011, at 12:12 PM, Frederic Junod wrote:
> Hello,
> http://trac.osgeo.org/openlayers/ticket/1633 removes the dependency on
> AnchoredBubble and Marker from OpenLayers.Feature in order to get
> smaller build.
> The proposed patch removes the two requires, adapt the code and unit
> tests without functionality change.
> But there's a backward incompatibility change: with custom build, the
> createPopup and createMarker functions will require the two files to
> be manually added to the build config file.
> I think that adding a note on
> http://trac.osgeo.org/openlayers/wiki/Release/2.11/Notes is
> sufficient.
> Do you agree ?
> fredj
> Frédéric Junod
> Camptocamp SA
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev mailing list
