[OpenLayers-Dev] #1633: remove dependency on popup and marker from vector feature
Eric Lemoine eric.lemoine at camptocamp.com
Wed Mar 30 07:28:51 EDT 2011
On Wed, Mar 30, 2011 at 12:12 PM, Frederic Junod
<frederic.junod at camptocamp.com> wrote:
> Hello,
> http://trac.osgeo.org/openlayers/ticket/1633 removes the dependency on
> AnchoredBubble and Marker from OpenLayers.Feature in order to get
> smaller build.
> The proposed patch removes the two requires, adapt the code and unit
> tests without functionality change.
> But there's a backward incompatibility change: with custom build, the
> createPopup and createMarker functions will require the two files to
> be manually added to the build config file.
> I think that adding a note on
> http://trac.osgeo.org/openlayers/wiki/Release/2.11/Notes is
> sufficient.
> Do you agree ?
+1
Thanks fredj.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev mailing list
