[OpenLayers-Dev] Headers in WMS Layer
Alexandre Busquets
abusquets at gmail.com
Fri Apr 4 03:43:18 PDT 2014
Hi Moises,
I think that you have to get the images through a proxy.
2014-04-04 11:52 GMT+02:00 Moises Arcos <marcos at emergya.com>:
> Thanks for the answer.
> I have been trying your way and it doesn't work, I get a status code 200
> but a white image on map.
> I don't know what more to do, any suggestion?
> Regards!!!
> 2014-04-04 11:37 GMT+02:00 Andreas Hocevar <ahocevar at boundlessgeo.com>:
> This will not work. WMS requests in OpenLayers are pure image
>> requests, handled by the browser. But it looks like what you want is
>> plain HTTP Basic authentication, which is supported by all browsers.
>> So you could just change your layer_url to:
>> http://user:pass@rest_of_your_url/wms/
>> I'm sure I do not need to tell you that doing this is equivalent to
>> sharing credentials with the whole world.
>> Andreas.
>> On Fri, Apr 4, 2014 at 11:30 AM, Moises Arcos <marcos at emergya.com> wrote:
>> > Hi developers,
>> > I am using OpenLayers 2.11 to display WMS Layers, but I need any help,
>> > because I am trying to pass authorization headers into a WMS request,
>> but I
>> > don't know if it's possible.
>> > The request that I sent is:
>> > var layer = new OpenLayers.Layer.WMS(
>> > layerData.name,
>> > layer_url,
>> > layers: layers
>> > headers: {
>> > 'Authorization': 'Basic user:pass'
>> > I know that the better options to do this is throught a proxy, but I
>> need to
>> > do this temporaly.
>> > Regards!!!
>> > Moisés Arcos Santiago
>> > Área de Proyectos
>> > Emergya Consultoría
>> > Tfno: +34 954 51 75 77
>> > Fax: +34 954 51 64 73
>> > www.emergya.es
>> > _______________________________________________
>> > Dev mailing list
>> > Dev at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>> Andreas Hocevar
>> Geospatial Solutions Engineer | Boundless
>> @boundlessgeo
> Área de Proyectos
> Emergya Consultoría
> www.emergya.es
> Dev mailing list
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20140404/9d86e6a3/attachment.html>
More information about the Dev
