[OpenLayers-Dev] Headers in WMS Layer
Moises Arcos marcos at emergya.com
Fri Apr 4 03:46:48 PDT 2014
Yes, I think it is the better way to do it, but I need a solution
temporally while we deploy the new proxy.
Thank you for your aswer.
2014-04-04 12:43 GMT+02:00 Alexandre Busquets <abusquets at gmail.com>:
> Hi Moises,
> I think that you have to get the images through a proxy.
> 2014-04-04 11:52 GMT+02:00 Moises Arcos <marcos at emergya.com>:
> Thanks for the answer.
>> I have been trying your way and it doesn't work, I get a status code 200
>> but a white image on map.
>> I don't know what more to do, any suggestion?
>> Regards!!!
>> 2014-04-04 11:37 GMT+02:00 Andreas Hocevar <ahocevar at boundlessgeo.com>:
>> This will not work. WMS requests in OpenLayers are pure image
>>> requests, handled by the browser. But it looks like what you want is
>>> plain HTTP Basic authentication, which is supported by all browsers.
>>> So you could just change your layer_url to:
>>> http://user:pass@rest_of_your_url/wms/
>>> I'm sure I do not need to tell you that doing this is equivalent to
>>> sharing credentials with the whole world.
>>> Andreas.
>>> On Fri, Apr 4, 2014 at 11:30 AM, Moises Arcos <marcos at emergya.com>
>>> wrote:
>>> > Hi developers,
>>> > I am using OpenLayers 2.11 to display WMS Layers, but I need any help,
>>> > because I am trying to pass authorization headers into a WMS request,
>>> but I
>>> > don't know if it's possible.
>>> > The request that I sent is:
>>> > var layer = new OpenLayers.Layer.WMS(
>>> > layerData.name,
>>> > layer_url,
>>> > layers: layers
>>> >     headers: {
>>> >                      'Authorization': 'Basic user:pass'
>>> > I know that the better options to do this is throught a proxy, but I
>>> need to
>>> > do this temporaly.
>>> > Regards!!!
>>> > Moisés Arcos Santiago
>>> > Área de Proyectos
>>> > Emergya Consultoría
>>> > Tfno: +34 954 51 75 77
>>> > Fax: +34 954 51 64 73
>>> > www.emergya.es
>>> > _______________________________________________
>>> > Dev mailing list
>>> > Dev at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>>> Andreas Hocevar
>>> Geospatial Solutions Engineer | Boundless
>>> @boundlessgeo
>> Área de Proyectos
>> Emergya Consultoría
>> www.emergya.es
>> Dev mailing list
Área de Proyectos
Emergya Consultoría
www.emergya.es
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20140404/ea9dba8a/attachment-0001.html>
More information about the Dev mailing list
