[OpenLayers-Users] Fwd: R: R: Locator
Christopher Schmidt crschmidt at metacarta.com
Fri Nov 17 10:40:06 EST 2006
Forgot to send this one to the list. Someone else asked, so I'm
resending to increase the general knowledge of the world.
> (If you could set your mail client to not send HTML emails, it would
> be helpful -- my main client can't read the HTML.)
> On Nov 17, 2006, at 4:46 AM, Jacopo Boari wrote:
>> Sorry another little question, I'm writing on my Web Page the same
>> code of the example, But when I reload the page, I see the
>> OverviewMap on the Top/Left of the map and not in the default
>> position. Anybody know why?
> The position of the Overview Map is controlled by CSS, loaded to the
> page automatically when the map is created. This CSS is stored in the
> 'theme' directory: if you do not have a theme directory alongside the
> 'img' directory that OpenLayers is using, this CSS can not be loaded,
> and the map will be displayed in the upper left, instead of the
> properly CSS positioned lower right.
> Can you verify that you have a 'theme' directory in the same
> directory as your OpenLayers image directory?
> Regards,
> Christopher Schmidt
> MetaCarta
Christopher Schmidt
MetaCarta
