[OpenLayers-Users] Fwd: R: R: Locator
Erik Uzureau euzuro at gmail.com
Fri Nov 17 14:06:54 EST 2006
http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#OverviewMap
On 11/17/06, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> Forgot to send this one to the list. Someone else asked, so I'm
> resending to increase the general knowledge of the world.
> > (If you could set your mail client to not send HTML emails, it would
> > be helpful -- my main client can't read the HTML.)
> > On Nov 17, 2006, at 4:46 AM, Jacopo Boari wrote:
> >> Sorry another little question, I'm writing on my Web Page the same
> >> code of the example, But when I reload the page, I see the
> >> OverviewMap on the Top/Left of the map and not in the default
> >> position. Anybody know why?
> > The position of the Overview Map is controlled by CSS, loaded to the
> > page automatically when the map is created. This CSS is stored in the
> > 'theme' directory: if you do not have a theme directory alongside the
> > 'img' directory that OpenLayers is using, this CSS can not be loaded,
> > and the map will be displayed in the upper left, instead of the
> > properly CSS positioned lower right.
> > Can you verify that you have a 'theme' directory in the same
> > directory as your OpenLayers image directory?
> > Regards,
> > Christopher Schmidt
> > MetaCarta
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
