[OpenLayers-Users] google.html with IE
Arnd Wippermann arnd.wippermann at web.de
Tue Nov 21 15:17:26 EST 2006
Hello Eric,
The response for the first link is this:
 The requested URL /dev/examples/google.html was not found on this server.
The second link shows the example page. With FF the layers will drawn
correct. But in IE6 i don't see the Google Map, because the freemap layer
isn't transparent. When you look at the source, you can see, that the
imageformat parameter for the wms layer is not 'image/png'. It doesn't
disturb FF. I have saved the page locally and changed this parameter and
then in IE the tiles will be transparent. But only to show mostly the red
borders of the countries above pink background. Some tiles are correct, red
border on Google Map, others red borders on pink background. Is this a bug
with IE? I'm also not able to use opacity in IE.
Some questions and suggestions to the example:
1. Why can't Openlayers show Google Maps in the highest zoomlevel, which
Google Maps shows self in the Internet?
2. Why are WMS layers disabled at a certain zoomlevel (2 under maxzoomlevel
(18) of the Google layer), in spite of 'numZoomLevels':20?
3. The deleting of a displayed marker isn't possibly, when you twice clicked
on add marker.
4. I have seen, that in Openlayers 2.2 exists a variable
OpenLayers.VERSION_NUMBER="$Revision: 1865 $". Is there something, what
shows the Version of Openlayers i.e "2.2-rc1", because "$Revision: 1865 $"
isn't straight clear?
5. The layer "OpenLayers WMS" are tho times declared and add to the map.
I hope the above helps.
Mit freundlichen Grüssen
Arnd Wippermann
http://gis.ibbeck.de/ginfo/ibbOLClient/OpenLayersClient.html
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Erik Uzureau
Gesendet: Dienstag, 21. November 2006 13:43
An: Mario Basa
Cc: users at openlayers.org
Betreff: Re: [OpenLayers-Users] google.html with IE
In theory, the openlayers.org/dev directory is connected by a post-commit
hook to the trunk itself, so all the examples there should be running on the
latest from trunk (which at this point is 2.2 plus a few new patches)
both
http://svn.openlayers.org/dev/examples/google.html
_and_
http://www.postlbs.org/postlbs-ol/google.html
Seem to work fine in my IE on XP
Can anyone elese corroborate?
Erik
On 11/18/06, Mario Basa <mario.basa at gmail.com> wrote:
> Hello Erik,
> Thanks.
> I was referring though to the example google.html included in the 2.2
> package and using the 2.2 OL lib. The openlayers.org link also loaded
> in my IE6-J. My apologies for not being so clear.
> The link below loads fine with firefox and safari but breaks with
> IE6-J (XP &W2K):
> Regards,
> Mario.
> On 11/18/06, Erik Uzureau <euzuro at gmail.com> wrote:
> > Hi Mario
> > I just loaded
> > http://www.openlayers.org/dev/examples/google.html
> > in my IE6 browser on XP and it seems to load ok.
> > Erik
> > On 11/17/06, Mario Basa <mario.basa at gmail.com> wrote:
> > > Hello.
> > > I don't know if it is because I am using a Japanese version, which
> > > has issues with the google api key, but the examples/google.html
> > > seems to break with IE. The error message says that the
> > > GOOGLE_SATTELITE tag is not defined. The sample app works well with
Safari and Firefox though.
> > > Will really appreciate it if somebody with a non-Japanese version
> > > of IE can verify this.
> > > Regards,
> > > Mario.
> > > _______________________________________________
> > > Users mailing list
> > > Users at openlayers.org
> > > http://openlayers.org/mailman/listinfo/users
Users mailing list
