[OpenLayers-Users] Problems setting up TileCache
Christopher Schmidt crschmidt at metacarta.com
Wed Nov 22 14:05:28 EST 2006
On Wed, Nov 22, 2006 at 08:56:29AM -0800, Ben Brehmer wrote:
> Christopher Schmidt wrote:
> >We're using Python2.4 for our TileCache workings, but I know that people
> >have got it running under 2.3 -- this error is definitely something you
> >wouldn't see under Python2.4, but I don't know if that would fix your
> >problem.
> >I've just downloaded a clean TileCache 1.1, and edited tilecache.cgi to
> >use Python2.3, and I'm not getting this error, unfortunately. If you
> >could give any more information as to where in the code this error is
> >happening, I'd appreciate it, and will investigate as best I can.
> >Regards,
> Hi Christopher,
> This is the complete error log:
> [Wed Nov 22 08:48:23 2006] [error] [client 192.168.50.1] Traceback (most
> recent call last):
> [Wed Nov 22 08:48:23 2006] [error] [client 192.168.50.1]   File
> "/home/httpd/cf2/cgi-bin/tilecache-1.1/tilecache.cgi", line 6, in ?
> [Wed Nov 22 08:48:23 2006] [error] [client 192.168.50.1]     svc =
> Service.load(*cfgfiles)
> "/home/httpd/cf2/cgi-bin/tilecache-1.1/TileCache/Service.py", line 249,
> in _load
> [Wed Nov 22 08:48:23 2006] [error] [client 192.168.50.1]     cache =
> cls.loadFromSection(config, "cache", Cache)
> "/home/httpd/cf2/cgi-bin/tilecache-1.1/TileCache/Service.py", line 232,
> in _loadFromSection
> [Wed Nov 22 08:48:23 2006] [error] [client 192.168.50.1]     if opt not
> in ("type"):
> [Wed Nov 22 08:48:23 2006] [error] [client 192.168.50.1] TypeError: 'in
> <string>' requires character as left operand
> [Wed Nov 22 08:48:23 2006] [error] [client 192.168.50.1] Premature end
> of script headers: tilecache.cgi
> I definitely agree with you that this is a problem in ConfigParser,
> although this may be related to me using Python 2.2.3. I am going to
> install Python 2.4 this morning. I"ll let you know if that was the cause
> of my problems.
Ah, 2.2 is not supported -- I don't have it available on the machine I"m
using, or on the server :)
However, it does explain why you got this message: Python2.2 doesn't
support the construct:
'string' in ("type")
A single element tuple is converted immediately to a string. (Python2.3
and python 2.4 apparently don't do this.)
To test whether it works with 2.2, you can change ("type") to ['type']
on line 232 of TileCache/Service.py: in a quick test on my local copy of
TileCache, this works, but we have thus far not put any effort into
maintaining compatibility with 2.2, only 2.3 and up.
Regards,
Christopher Schmidt
MetaCarta
