[OpenLayers-Users] [Users] Help on WFS Example Urgently Required
Erik Uzureau euzuro at gmail.com
Wed Oct 18 09:49:49 EDT 2006
>From a previous post by chris schmidt:
Due to security restrictions in Javascript, it is not possible to
retrieve information from remote domains via XMLHttpRequest. The way to
work around this is to set up a local script which can 'proxy'
information from the remote host. An example script to do this is
available from the examples directory as proxy.cgi:
http://svn.openlayers.org/trunk/openlayers/examples/proxy.cgi
To use WFS results from a remote host on your machine, you must install
a proxy script somewhere web accessible from the domain you plan to use
to host your page. You must then edit ProxyHost to match that URL: an
example URL for most Apache configurations might be:
OpenLayers.ProxyHost="/cgi-bin/proxy.cgi?url=";
If the ProxyHost is not set, requests are sent directly. In most cases,
the result will be a security exception.
If you are still having problems with this, please send a link to an
example page on the web where the WFS example fails.
On 10/15/06, ngsuwei at stee.stengg.com <ngsuwei at stee.stengg.com> wrote:
> I have downloaded the latest codes using svn. However the WFS example is
> not working. But the one in the live example is working. Is it because the
> downloaded code is not latest code as the one in live example or is there
> any missing configuration at my side? I saw the codes there is this proxy
> thing, what is this for or do i need to set up one? Immediate help is very
> appreciated as i am reaching my deadline for the WFS portion to work.
> Thanks in advance.
> [This e-mail is confidential and may be priviledged. If you are not the
> intended recipient, please kindly notify us immediately and delete the message
> from your system; please do not copy or use it for any purpose, nor disclose
> its contents to any other person. Thank you.]
> ---ST Electronics Group---
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
