[OpenLayers-Users] [Users] baselayer
Erik Uzureau euzuro at gmail.com
Wed Oct 18 13:53:24 EDT 2006
Dear Bart,
Thank you for the elaboration. The point that you bring up is a good
and valid one.
I think the most reasonable solution for this is to provide a way of making the
current baselayer invisible.
I have made a ticket for this in OpenLayers TRAC:
http://trac.openlayers.org/ticket/354
Feel free to add any comments or make any changes to that ticket.
Thanks for your input!
--Erik
On 10/18/06, Bart van den Eijnden (OSGIS) <bartvde at osgis.nl> wrote:
> Hi Erik,
> maybe the following use case:
> displaying a thematic layer on top of a base layer (aerial photograph).
> To get a clearer view of the thematic map, it might help if someone can
> switch off the base layer, so the colours will come out clearer against
> a white background.
> Also, it's what I am used to when using clients like Chameleon or
> Mapbuilder, but that's not the best of reasons ofcourse :-)
> Best regards,
> Bart
> Erik Uzureau schreef:
> > Dear Bart,
> > Yes it is necessary to always have one BaseLayer in OpenLayers. All of the
> > calculations are done based on the functionality that a baselayer provides.
> > Can you explain maybe a little bit more why someone would like to have a map
> > without a baselayer? Maybe there is a good solution  to this problem. :-)
> > Thanks,
> > Erik
> > On 10/15/06, Bart van den Eijnden (OSGIS) <bartvde at gmail.com> wrote:
> >> Hi list,
> >> is it necessary to always have a BaseLayer in the OpenLayers model? I
> >> haven't got anything to work without saying one of the layers is the
> >> baselayer.
> >> Why can't I have 5 WMS layers, and give the user the possiblity to turn
> >> them all on or off?
> >> Best regards,
> >> Bart
> >> OSGIS, Open Source GIS
> >> bartvde at osgis.nl
> >> http://www.osgis.nl
> >> _______________________________________________
> >> Users mailing list
> >> Users at openlayers.org
> >> http://openlayers.org/mailman/listinfo/users
> > Users mailing list
> bartvde at osgis.nl
> http://www.osgis.nl
