[OpenLayers-Users] [Users] baselayer
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Wed Oct 18 13:18:38 EDT 2006
Hi Erik,
maybe the following use case:
displaying a thematic layer on top of a base layer (aerial photograph).
To get a clearer view of the thematic map, it might help if someone can
switch off the base layer, so the colours will come out clearer against
a white background.
Also, it's what I am used to when using clients like Chameleon or
Mapbuilder, but that's not the best of reasons ofcourse :-)
Best regards,
Bart
Erik Uzureau schreef:
> Dear Bart,
> Yes it is necessary to always have one BaseLayer in OpenLayers. All of the
> calculations are done based on the functionality that a baselayer provides.
> Can you explain maybe a little bit more why someone would like to have a map
> without a baselayer? Maybe there is a good solution  to this problem. :-)
> Thanks,
> Erik
> On 10/15/06, Bart van den Eijnden (OSGIS) <bartvde at gmail.com> wrote:
>> Hi list,
>> is it necessary to always have a BaseLayer in the OpenLayers model? I
>> haven't got anything to work without saying one of the layers is the
>> baselayer.
>> Why can't I have 5 WMS layers, and give the user the possiblity to turn
>> them all on or off?
>> Best regards,
>> Bart
>> OSGIS, Open Source GIS
>> bartvde at osgis.nl
>> http://www.osgis.nl
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
bartvde at osgis.nl
http://www.osgis.nl
