[OpenLayers-Users] Mouse position control
Erik Uzureau euzuro at gmail.com
Tue Oct 24 11:59:45 EDT 2006
Note that this patch has been applied to both trunk/openlayers
and branches/openlayers/2.2, so if you are working from trunk
an svn update should do the trick, and it will be part of the next
release candidate as well.
Ticket #372 closed (http://trac.openlayers.org/ticket/372#preview)
Great work everyone!
--Erik
On 10/24/06, Jeff Dege <jdege at korterra.com> wrote:
> Don't kick yourself too hard - the description in the doc file dates
> from when the granularity setting worked the way you had thought it had
> worked.  I updated the code, and forgot to update the docs.
> I've submitted a patch to the docs so that the description for the
> granularity setting matches what the granularity setting does do,
> instead of what it used to do back when the control wasn't working.
> And I've bumped the default value from 1 to 10 - which should make even
> folks with fast mouses update the display.
> You can, if you like, set granularity to > window size, and have it
> update the display all the time.  Personally, I really hate jerky mouse
> movement, but others might not be as sensitive.
> > -----Original Message-----
> > From: users-bounces at openlayers.org
> > [mailto:users-bounces at openlayers.org] On Behalf Of Alan U
> > Sent: Tuesday, October 24, 2006 10:22 AM
> > To: users at openlayers.org
> > Subject: Re: [OpenLayers-Users] Mouse position control
> > I take it all back (almost!)
> > There isn't necessarily a problem with the code, but I always
> > have my mouse
> > on fast pointer movement. This was never giving me a
> > mouse-movement < 2
> > pixels.
> > DOH!!
> > Turning down the sensitivity of my mouse and the code works
> > (of course). It
> > only updates the control display if the mouse-movement is
> > small enough and
> > mine wasn't.
> > Therefore, the default granularity should be raised or anyone
> > running the
> > examples/default code will see no feed back from the
> > mousePosition control!
> > My final points about not being able to get latlong values
> > when moving the
> > mouse slowly are rubbish too.
> > Alan (gently kicking myself)
> > Alan U wrote:
> > > Taking the code from the trunk, the mouse position control
> > seems a bit
> > > wrong. I was getting no feedback in FF and only feedback in
> > IE when making
> > > a click on the map.
> > > In the redraw function I changed:
> > >             if (this.lastXy == null ||
> > >                 Math.abs(evt.xy.x - this.lastXy.x) >
> > this.granularity ||
> > >                 Math.abs(evt.xy.y - this.lastXy.y) >
> > this.granularity)
> > >             { //don't update
> > > to:
> > >                 Math.abs(evt.xy.x - this.lastXy.x) <
> > this.granularity ||
> > >                 Math.abs(evt.xy.y - this.lastXy.y) <
> > this.granularity)
> > >             {//don't update
> > > Note the greater/less than signs.
> > > Also, with the granularity value even set to 1, moving
> > slowly across the
> > > map causes no update of the xy coords in the control. Though this is
> > > designed for, it is not intuitive imo. If you are trying to get a
> > > coordinate precisely, then it is highly likely you will be
> > moving the
> > > mouse below the granularity level: thus I think the default
> > should be 0.
> > > Alan
> > View this message in context:
> > http://www.nabble.com/Mouse-position-control-tf2501061.html#a6974998
> > Sent from the OpenLayers Users mailing list archive at Nabble.com.
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20061024/479a68c8/attachment.html
