[OpenLayers-Users] Work around for bug #541 ??
Schuyler Erle sderle at metacarta.com
Mon Apr 2 01:13:58 EDT 2007
On Sun, 2007-04-01 at 22:56 -0400, Stephen Woodbridge wrote:
> I ran into a small problem with the trunk build script:
> Resolution pass 1...
> Importing: OpenLayers/Format/JSON.js
> Traceback (most recent call last):
>    File "./build.py", line 18, in ?
>      merged = mergejs.run(sourceDirectory, None, configFilename)
>    File "../tools/mergejs.py", line 190, in run
>      content = open(fullpath, "U").read() # TODO: Ensure end of line @ EOF?
> IOError: [Errno 2] No such file or directory:
> '../lib/OpenLayers/Format/JSON.js'
I've just filed ticket #615 over this, because I can't figure out if the
references to JSON.js belong and the file is missing, or the references
are actually extraneous and should be removed. Bueller?
SDE
