[OpenLayers-Users] Navigation Toolbar using Panel inheritance
Lee Keel lee.keel at uai.com
Tue Apr 10 14:51:12 EDT 2007
I meant to add that the script tag for the openlayers.js is from an internal
location which is a built version of the trunk from last Thursday (April 5,
2007).  I had to use this because I didn't know where a published copy of
the main trunk was located.
Thanks,
Lee
  _____
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On
Behalf Of Lee Keel
Sent: Tuesday, April 10, 2007 1:42 PM
To: dev at openlayers.org; users at openlayers.org
Subject: [OpenLayers-Users] Navigation Toolbar using Panel inheritance
I had to create a toolbar for an application I am working on that would
allow undo\redo of extent changes.  I thought that it might come in handy
for someone if they would like to use it.  I have attached all the files
that I used to configure it because I was not 100% sure on how to submit as
a new feature.  I am very new to JavaScript, so please be kind in your
comments about the crudeness of the code.  However, I am very open to any
suggestions of improving this code or if this was already available in some
other way.
Also, could someone inform me on how to be able to submit feature
request\changes?  I would like to be able to submit some changes in the
future as my skill level increases and I find things to tweak.
Thanks,
Lee
This email and any files transmitted with it are confidential and intended
solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the sender. This
message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not
disseminate, distribute or copy this e-mail.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070410/657e5257/attachment.html
