[OpenLayers-Users] Navigation Toolbar using Panel inheritance
Erik Uzureau erik.uzureau at metacarta.com
Tue Apr 10 16:57:48 EDT 2007
Published copy of main trunk is always at:
http://www.openlayers.org/api/OpenLayers.js
erik
On 4/10/07, Lee Keel <lee.keel at uai.com> wrote:
> I meant to add that the script tag for the openlayers.js is from an internal
> location which is a built version of the trunk from last Thursday (April 5,
> 2007).  I had to use this because I didn't know where a published copy of
> the main trunk was located.
>  Thanks,
>  Lee
>  ________________________________
> From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On
> Behalf Of Lee Keel
>  Sent: Tuesday, April 10, 2007 1:42 PM
>  To: dev at openlayers.org; users at openlayers.org
>  Subject: [OpenLayers-Users] Navigation Toolbar using Panel inheritance
> I had to create a toolbar for an application I am working on that would
> allow undo\redo of extent changes.  I thought that it might come in handy
> for someone if they would like to use it.  I have attached all the files
> that I used to configure it because I was not 100% sure on how to submit as
> a new feature.  I am very new to JavaScript, so please be kind in your
> comments about the crudeness of the code.  However, I am very open to any
> suggestions of improving this code or if this was already available in some
> other way.
> Also, could someone inform me on how to be able to submit feature
> request\changes?  I would like to be able to submit some changes in the
> future as my skill level increases and I find things to tweak.
> Thanks,
> Lee
> This email and any files transmitted with it are confidential and intended
> solely for the use of the individual or entity to whom they are addressed.
> If you have received this email in error please notify the sender. This
> message contains confidential information and is intended only for the
> individual named. If you are not the named addressee you should not
> disseminate, distribute or copy this e-mail.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
