[OpenLayers-Users] question about overlays
bradleyspencer brad at cubewerx.com.au
Tue Apr 10 22:02:36 EDT 2007
Adam,
The hard way to go is to use the OGC specs for SLD definitions,
alternatively you could just search for other SLD files and cut and paste
try http://www.cubewerx.com.au/mesh04.xml.
However, your WMS service must support SLDs so check that first, if not you
might like to consider CubeWerx’s products ;)
Other than that you can use the DemoDrapes demo I sent you as an example of
how to apply SLDs in an OL application as its not clearly documented.
Cheers,
Brad Spencer
General Manager
CubeWerx Australia Pty Ltd
ABN: 37 115 163 285
Mob: +61 (0)404 841 131
Tel/Fax: +61 (0)2 9481 7024
mailto:brad at cubewerx.com.au
-----Original Message-----
Sent: Wednesday, 11 April 2007 11:55 AM
To: brad at cubewerx.com.au
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] question about overlays
very interesting...does anyone have any resources/tutorials for me to get
started with this stuff?
On 4/10/07, bradleyspencer < brad at cubewerx.com.au
<mailto:brad at cubewerx.com.au> > wrote:
Adam,
Have you thought about creating the thematic overlays interactively using
SLDs?
See http://www.cubewerx.com.au/DemoDrapes.html
Cheers,
Brad Spencer
General Manager
ABN: 37 115 163 285
mailto: brad at cubewerx.com.au <mailto:brad at cubewerx.com.au>
From: Adam Eskreis [mailto: aeskreis at gmail.com <mailto:aeskreis at gmail.com> ]
Sent: Wednesday, 11 April 2007 10:24 AM
To: users at openlayers.org <mailto:users at openlayers.org>
Subject: [OpenLayers-Users] question about overlays
I am currently constructing a map with many thematic layers.  For those that
don't know, a thematic layer is a layer which color codes certain polygons
based on a certain field, such as population density or something like that.
I want these thematic layers to be able to be turned on and off.  I have
each thematic layer set up as a seperate group in the mapfile, and i set up
each one as a seperate overlay in openlayers.  However, my problem is now i
have around 40 overlays on my OpenLayers map.  Is this too many?  It is
taking a long time to load the map now.  So my question, is having a lot of
overlays bad practice?  If so, how can i cut down on overlays, but still be
able to have each thematic layer be able to be shown on demand by the user?
Thanks.
-Adam
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070411/238d1828/attachment.html
