[OpenLayers-Users] Select mode in browser?
Christopher Schmidt crschmidt at metacarta.com
Wed Apr 11 15:58:12 EDT 2007
On Wed, Apr 11, 2007 at 02:26:43PM -0500, Jeff Dege wrote:
> I'm drawing a vector layer over the top of a KaMap layer, and things are
> working pretty well.  But there's this irritating artifact:
> Intermittently, as I draw on the map, the browser will decide I'm trying
> to select things, instead of draw things, and everything on the map will
> be colored a dark blue.  Clicking outside the map div will make it go
> away, and while it's there it's only visually confusing, it doesn't
> actually break anything.
> But is there any way of keeping it from happening?
Are you in IE? Are you running trunk or RC1? This should be fixed in
trunk.
Regards,
Christopher Schmidt
MetaCarta
