[OpenLayers-Users] Markers and Projections
Cicconetti, Bob BCicconetti at dnr.state.md.us
Fri Apr 13 10:57:03 EDT 2007
See:
http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#Projections
If all of your data is in EPSG:27582, it would be easier to just set the projection in your map object, and don't hardcode the epsg code in your WMS url. For example, I use 26985:
  var map = new OpenLayers.Map("map",
  	{maxExtent: new OpenLayers.Bounds(397000, 112000, 469000, 179000),
	units: "m",
	projection: "EPSG:26985",
	tileSize: new OpenLayers.Size(512,512)
  var layer = new OpenLayers.Layer.WMS( "Spring 05 0.5ft",
              "http://cac0076568/cgi-bin/mapserv.exe?map=/aac1.map",
	      {layers: 'AACo_2005_0.5ft_Spring' },
	      {isBaseLayer: true});
  map.addLayer(layer);
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On Behalf Of david delannoy
Sent: Friday, April 13, 2007 9:22 AM
To: users at openlayers.org
Subject: [OpenLayers-Users] Markers and Projections
Hello,
I'm trying to display markers on a map wich display a layer in
projection 27582. It seems that it doesn't work while it works for the
projection 4269. Here is a part of my code.
Thank in advance for your help.
       var llon = 658500;
       var llat = 2380000;
       var options = {
                  maxResolution: "auto",
                  /* maxExtent is the maximum bounds, in the units of
your map,
                  of the plane in which you want to display information */
                  maxExtent: new
OpenLayers.Bounds(50000,1586013,1160964,2771788),
                  /* maxExtent is the minimum bounds, in the units of
your map,
                  minExtent: new
                  /* Number of zoom levels */
                  numZoomLevels: 4,
                  /* Unit of geographical values on the map */
                  units : "meters"
          var ol_wms = new OpenLayers.Layer.WMS( "OpenLayers WMS",
              "http://www.geosignal.org/cgi-bin/wmsmap?SRS=EPSG:27582&",
          {layers: 'RASTER1000k',transparent: "false", format:
"image/png"}, options);
          map.addLayer(ol_wms);
                    /* Ajout de markers */
          var markers = new OpenLayers.Layer.Markers( "Markers" );
          map.addLayer(markers);
          var size = new OpenLayers.Size(20,30);
          var offset = new OpenLayers.Pixel(-(size.w/2), -size.h);
          var icon = new
OpenLayers.Icon('http://boston.openguides.org/markers/RED.png',size,offset);
          var marker = new OpenLayers.Marker(new
OpenLayers.LonLat(llon,llat),icon);
          markers.addMarker(marker);
          marker.events.register('mousedown', marker, function(evt) {
alert(this.icon.url); Event.stop(evt); });
          map.addControl(new OpenLayers.Control.LayerSwitcher());
          map.zoomToMaxExtent();
David DELANNOY
Ingénieur en Bioinformatique
Unité Agroclim
Site Agroparc
INRA AVIGNON
david.delannoy at avignon.inra.fr
04 32 72 24 13
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
