[OpenLayers-Users] Markers and Projections
david delannoy
david.delannoy at avignon.inra.fr
Fri Apr 13 11:21:13 EDT 2007
Cicconetti, Bob a écrit :
> See:
> http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#Projections
> If all of your data is in EPSG:27582, it would be easier to just set the projection in your map object, and don't hardcode the epsg code in your WMS url. For example, I use 26985:
> var map = new OpenLayers.Map("map",
> {maxExtent: new OpenLayers.Bounds(397000, 112000, 469000, 179000),
> units: "m",
> projection: "EPSG:26985",
> tileSize: new OpenLayers.Size(512,512)
> var layer = new OpenLayers.Layer.WMS( "Spring 05 0.5ft",
> "http://cac0076568/cgi-bin/mapserv.exe?map=/aac1.map",
> {layers: 'AACo_2005_0.5ft_Spring' },
> {isBaseLayer: true});
> map.addLayer(layer);
> -----Original Message-----
> From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On Behalf Of david delannoy
> Sent: Friday, April 13, 2007 9:22 AM
> To: users at openlayers.org
> Subject: [OpenLayers-Users] Markers and Projections
> Hello,
> I'm trying to display markers on a map wich display a layer in
> projection 27582. It seems that it doesn't work while it works for the
> projection 4269. Here is a part of my code.
> Thank in advance for your help.
> var llon = 658500;
> var llat = 2380000;
> var options = {
> maxResolution: "auto",
> /* maxExtent is the maximum bounds, in the units of
> your map,
> of the plane in which you want to display information */
> maxExtent: new
> OpenLayers.Bounds(50000,1586013,1160964,2771788),
> /* maxExtent is the minimum bounds, in the units of
> your map,
> minExtent: new
> /* Number of zoom levels */
> numZoomLevels: 4,
> /* Unit of geographical values on the map */
> units : "meters"
> var ol_wms = new OpenLayers.Layer.WMS( "OpenLayers WMS",
> "http://www.geosignal.org/cgi-bin/wmsmap?SRS=EPSG:27582&",
> {layers: 'RASTER1000k',transparent: "false", format:
> "image/png"}, options);
> map.addLayer(ol_wms);
> /* Ajout de markers */
> var markers = new OpenLayers.Layer.Markers( "Markers" );
> map.addLayer(markers);
> var size = new OpenLayers.Size(20,30);
> var offset = new OpenLayers.Pixel(-(size.w/2), -size.h);
> var icon = new
> OpenLayers.Icon('http://boston.openguides.org/markers/RED.png',size,offset);
> var marker = new OpenLayers.Marker(new
> OpenLayers.LonLat(llon,llat),icon);
> markers.addMarker(marker);
> marker.events.register('mousedown', marker, function(evt) {
> alert(this.icon.url); Event.stop(evt); });
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> map.zoomToMaxExtent();
You're good!!! It works well now. Thank you very much!
David DELANNOY
Ingénieur en Bioinformatique
Unité Agroclim
Site Agroparc
INRA AVIGNON
04 32 72 24 13
