[OpenLayers-Users] Problems with svn head
Erik Uzureau erik.uzureau at metacarta.com
Thu Apr 19 14:17:41 EDT 2007
I played around with the site a little bit in FF and was able to reproduce
the map not dropping
bug, though I am still unsure what is causing it. a log of the errors from
firebug suggest it's
something to do with the gridding algorithm :-/
row[i] has no properties
while(this.grid.length>rowidx){var row=this.grid.pop();for(var i=0,l=
row.length;...
OpenLayers.js (line 730)
bottomLeftTile has no properties
if(bounds!=null){if(!this.grid.length||zoomChanged||!this.getGridBounds().contai...
OpenLayers.js (line 726)
On 4/19/07, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Christopher, et al,
> I have upgraded to todays svn and these issues persist.
> Is anyone else see these? Can you try the url below and see if you get
> them on my instance. Other users are reporting the same issues from that
> url.
> Thanks,
>    -Steve
> Stephen Woodbridge wrote:
> > Hi All,
> > I have two problems with last nights svn. Both these problems have been
> > around for a while, but I'm just now getting around to documenting them.
> > I am running FF 2.0.0.3 on WindowsNT and can probably reproduce these
> > issues on WinXP also. I'm running ./build.py full
> > 1) Memory Leaks
> > a) launch FF with Google as home page - 38M
> > b) goto http://data.dev.where2getit.com/~swoodbridge/ol/bi.html - 50M
> >     - I also get one error on this page. "row[i] has no properties"
> > c) open layerswitcher and select one extra layer - 50M
> > d) Zoom + 57M
> > e) Zoom + 68M
> > f) Pan map from UL to LR 75M
> > g) Zoom _ and a couple more pans 91M
> > the growth continues with interactions until I have to kill FF to
> > recover memory!!!
> > 2) map attached to cursor and requires an additional click to drop -
> > this is VERY annoying. Often when I pan the map does not drop from the
> > cursor and requires another click. Events are confused at this point for
> > example, I have an untiled overlay and it is not refreshed to the
> > current extents. The redraw event fires when the drag stops when you
> > would expect it to, but the mouse does not detach from the drag until
> > you provide a second click.
> > -Steve
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070419/143a9872/attachment.html
