[OpenLayers-Users] Problems with svn head
Stephen Woodbridge woodbri at swoodbridge.com
Thu Apr 19 13:12:18 EDT 2007
Christopher, et al,
I have upgraded to todays svn and these issues persist.
Is anyone else see these? Can you try the url below and see if you get
them on my instance. Other users are reporting the same issues from that
url.
Thanks,
   -Steve
Stephen Woodbridge wrote:
> Hi All,
> I have two problems with last nights svn. Both these problems have been
> around for a while, but I'm just now getting around to documenting them.
> I am running FF 2.0.0.3 on WindowsNT and can probably reproduce these
> issues on WinXP also. I'm running ./build.py full
> 1) Memory Leaks
> a) launch FF with Google as home page - 38M
> b) goto http://data.dev.where2getit.com/~swoodbridge/ol/bi.html - 50M
>     - I also get one error on this page. "row[i] has no properties"
> c) open layerswitcher and select one extra layer - 50M
> d) Zoom + 57M
> e) Zoom + 68M
> f) Pan map from UL to LR 75M
> g) Zoom _ and a couple more pans 91M
> the growth continues with interactions until I have to kill FF to
> recover memory!!!
> 2) map attached to cursor and requires an additional click to drop -
> this is VERY annoying. Often when I pan the map does not drop from the
> cursor and requires another click. Events are confused at this point for
> example, I have an untiled overlay and it is not refreshed to the
> current extents. The redraw event fires when the drag stops when you
> would expect it to, but the mouse does not detach from the drag until
> you provide a second click.
> -Steve
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
