[OpenLayers-Users] Problem with markers performence
suneel kota
suneel.kota at gmail.com
Tue Jan 9 01:30:56 EST 2007
Hi Christopher, Thanks for ur reply..
I am using IE for displaying the markers.. With out parsing
the xml file how can i get the latitude and longitude to display the markers
on the map..
Is there any other way to display lot of markers on the map.
I tried using text file and xml file with openlayers api.. Even its taking
much time..
can you give me any sample site which is using these type of requirement..
Thanks&Regards
SuneelKota
On 1/8/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> > please check my code which i am using ajax to display the markers..
> Which browser are you using to display the markers? As I said, IE
> performance at this scale is expected to be slow. Additionally, it looks
> like you may be parsing these markers out of XML: if so, you might find
> that this is actually where the slow behavior comes from, again,
> depending on your browser. DOM Manipulation can be expensive, and I
> wouldn't be surprised if this is what takes the time that you're seeing.
> Regards,
> Christopher Schmidt
> MetaCarta
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070109/ba641147/attachment.html
