[OpenLayers-Users] Defining zoom levels with Google Maps
kaka
drspencer at hotmail.com
Wed Jul 4 20:11:31 EDT 2007
I have tried using maxZoomLevel etc. but to my understanding, this only
decides if the layer should be drawn or not, and it does not actually define
the resolutions used. Is this correct? Also, I found some google maps
resolutions over at
http://dev.openlayers.org/docs/overview-summary-Google.js.html , but I am
not sure of how to insert them (3, to be exact) in my example. Any
suggestions? Many thanks for your rapid reply.
Magnus
Glen Stampoultzis-2 wrote:
> Well the resolutions are defined in an array called RESOLUTIONS in
> google.js.
> I'm guessing you could start by looking at altering that and/or
> MIN_ZOOM_LEVEL, MAX_ZOOM_LEVEL.
> On 05/07/07, kaka <drspencer at hotmail.com> wrote:
>> Hi
>> I am trying to create a map with only three zoom levels, using google
>> maps
>> as background. I have put up an example at
>> http://www.villageografica.com/test50/zoomLevels.html . I would like to
>> keep
>> the top three zoom levels and cut the lower six ones, but if I change the
>> number of zoom levels from 9 to 3, the map will be far too zoomed out on
>> first load, much more than intended,
>> http://www.villageografica.com/test50/zoomLevels2.html . Is there a way
>> to
>> define exactly which ones to use?
>> Magnus
>> View this message in context:
>> http://www.nabble.com/Defining-zoom-levels-with-Google-Maps-tf4027046.html#a11439053
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
View this message in context: http://www.nabble.com/Defining-zoom-levels-with-Google-Maps-tf4027046.html#a11439171
