[OpenLayers-Users] Defining zoom levels with Google Maps
Glen Stampoultzis gstamp at gmail.com
Thu Jul 5 02:08:48 EDT 2007
Just had a bit of a play and got it working.  Here's what I did:
map = new OpenLayers.Map( 'map' , { controls: [new
OpenLayers.Control.MouseDefaults()] , 'numZoomLevels':3});
var satellite = new OpenLayers.Layer.Google( "Google Satellite" , {type:
G_SATELLITE_MAP, MIN_ZOOM_LEVEL: 10, MAX_ZOOM_LEVEL: 13 } );
map.addLayers([satellite]);
You'll probably want to choose different MIN and MAX values but this seems
to work for me.
On 05/07/07, kaka <drspencer at hotmail.com> wrote:
> I have tried using maxZoomLevel etc. but to my understanding, this only
> decides if the layer should be drawn or not, and it does not actually
> define
> the resolutions used. Is this correct? Also, I found some google maps
> resolutions over at
> http://dev.openlayers.org/docs/overview-summary-Google.js.html , but I am
> not sure of how to insert them (3, to be exact) in my example. Any
> suggestions? Many thanks for your rapid reply.
> Magnus
> Glen Stampoultzis-2 wrote:
> > Well the resolutions are defined in an array called RESOLUTIONS in
> > google.js.
> > I'm guessing you could start by looking at altering that and/or
> > MIN_ZOOM_LEVEL, MAX_ZOOM_LEVEL.
> >> Hi
> >> I am trying to create a map with only three zoom levels, using google
> >> maps
> >> as background. I have put up an example at
> >> http://www.villageografica.com/test50/zoomLevels.html . I would like to
> >> keep
> >> the top three zoom levels and cut the lower six ones, but if I change
> the
> >> number of zoom levels from 9 to 3, the map will be far too zoomed out
> on
> >> first load, much more than intended,
> >> http://www.villageografica.com/test50/zoomLevels2.html . Is there a way
> >> to
> >> define exactly which ones to use?
> >> Magnus
> >> View this message in context:
> http://www.nabble.com/Defining-zoom-levels-with-Google-Maps-tf4027046.html#a11439053
> >> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> >> _______________________________________________
> >> Users mailing list
> >> Users at openlayers.org
> >> http://openlayers.org/mailman/listinfo/users
> > Users mailing list
> http://www.nabble.com/Defining-zoom-levels-with-Google-Maps-tf4027046.html#a11439171
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070705/1617d28f/attachment.html
