[OpenLayers-Users] Flicker while dragging map with vector in FF
bradleyspencer brad at cubewerx.com.au
Thu Jul 5 17:53:09 EDT 2007
Louvy,
I have the same problem I think. But this has a 'flickr' in both IE and FF.
http://www.ozdemo.org/
Just change base map to Google Maps (or Hybrid) and drag away. The
TerraPages is what I use as default and is a separate TileCached environment
and no flickr.
Cheers,
Brad Spencer
mailto:brad at cubewerx.com.au
http://www.cubewerx.com.au
-----Original Message-----
From: louvy.joseph at gmail.com [mailto:louvy.joseph at gmail.com]
Sent: Thursday, 5 July 2007 6:40 PM
To: Glen Stampoultzis
Cc: users at openlayers.org; Erik Uzureau
Subject: Re: [OpenLayers-Users] Flicker while dragging map with vector in FF
Glen, is your problem solved at all? I am also seeing similar issue with
Google as the base layer. While dragging the map, WFS layer seem to
smoothly drag but the underlying the Google turns white before coming
alive, thus resulting in flickr.
I am assuming that this is related to some kind of interaction between
the openlayers & google tile cacheing. Has anybody seen the issue?
Thanks
Louvy
Glen Stampoultzis wrote:
> Sorry for the late reply.  I'm just a plain old WMS layer.  If I'm the
> only one getting this I'll see if I can come up with a self contained
> example and stick is somewhere public.
> Regards,
> Glen
> On 28/04/07, *Erik Uzureau* <erik.uzureau at metacarta.com
> <mailto:erik.uzureau at metacarta.com>> wrote:
>     It might help to mention what layer you're using as a baselayer :-)
>     On 4/26/07, *Glen Stampoultzis* < gstamp at gmail.com
>     <mailto:gstamp at gmail.com>> wrote:
>         I'm using the vector support in RC2 to draw a route.  This is
>         working very nicely but in FF there's a very distracting
>         flicker when dragging the map around.  It appears where the
>         lines form triangles it get black area's that appear briefly
>         before things are redrawn.  Anyone seen this?  I'm afraid I
>         don't have a public facing example to show.
>         -- Glen
>         _______________________________________________
>         Users mailing list
>         Users at openlayers.org <mailto:Users at openlayers.org>
>         http://openlayers.org/mailman/listinfo/users
> Users mailing list
Users mailing list
