[OpenLayers-Users] Fwd: Problem with GML features
Dmitri Mizerkin
eisberg at gmail.com
Fri Jul 6 14:03:26 EDT 2007
Hello,
the workaround suggested by Tim will do it, because I want to zoom to a
single feature at this time.
Thanks for the help, guys!
Cheers,
Dmitri
2007/7/6, Erik Uzureau <erik.uzureau at metacarta.com>:
> I would note that the work that I'm doing in my untiled3 branch could
> be helpful for this.
> The problem is that WFS layer is no longer subclassed off of grid. I
> think this is a mistake, but so be it.
> At the very least, the work with sending loadStart and loadEnd events
> can be a good model.
> --erik
> On 7/6/07, Tim Schaub <noreply at geocartic.com> wrote:
> > Hey Dmitri-
> > Dmitri Mizerkin wrote:
> > > Hi!
> > > I haven't got any reaction to my previous mail, so I'm trying to point
> > > your attention to my problem again in this follow-up.
> > > The problem is: after loading a GML layer the features collection of
> the
> > > layer stays empty (at least for some time), which means that there's
> no
> > > way to handle those in the loadend-event of the layer. Is there
> another
> > > event, which is raised after the features collection of the loaded
> layer
> > > is initialized? Is there any rational workaround?
> > You're right. There is no good way to do what you want right now. I
> > assume you're talking about the WFS layer in vector mode (as opposed to
> > marker mode). When the tile for this layer is drawn a WFS request is
> > made asynchronously - when this request returns, the GML is parsed and
> > added to your layer. As each feature is added to your layer, the
> > optional onFeatureInsert property of your layer (a function) is called.
> > This is not handy if you want to know when the features are done being
> > added.
> > I thought there was a ticket out there already for this. I'll check -
> > and add one if not.
> > I'm hoping to do some work on the WFS layer in the near future. This
> > and other issues will likely get addressed then.
> > Tim
> > > Cheers,
> > > Dmitri Mizerkin
> > > ---------- Forwarded message ----------
> > > From: *Dmitri Mizerkin* <eisberg at gmail.com <mailto:eisberg at gmail.com>>
> > > Date: 05.07.2007 10:33
> > > Subject: Problem with GML features
> > > To: users at openlayers.org <mailto:users at openlayers.org>
> > > Hello everybody!
> > > I'm experiencing problems with handling the features of a GML layer,
> > > which is loaded when the page is opened. The problem is that after the
> > > 'loanend' event is raised, the features-property of the layer stays
> > > empty for some more time, so there is no way to examine the features
> in
> > > this handler. In my case I need to extract the bounds-properties of
> the
> > > features to construct an common bounds-object for zooming (the action
> > > should simulate feature selection and zooming to the selection).
> > > Any ideas, how this could work?
> > > Here's my code snapshot:
> > > function SelectFeature() {
> > > var layer = GetLayerByName(FEATURE_LAYER); //returns a MapServer
> layer
> > > to send a request on
> > > if (layer == null)
> > > return;
> > > var selection_url = CreateWFSGetFeatureRequest(layer, FIELD_NAME,
> > > FIELD_VALUE); //creates a WFS GetFeature-request
> > > if ((selection != null)&&(selection.map != null)) {
> > > OLMap.removeLayer (selection);
> > > selection = null;
> > > selection = new OpenLayers.Layer.GML("Selected Objects",
> selection_url);
> > > OLMap.addLayer(selection);
> > > selection.displayInLayerChooser = false;
> > > selection.events.register ("loadend", selection, ZoomToSelection);
> > > selection.events.triggerEvent("loadend");
> > > function ZoomToSelection() {
> > > var bounds = ComputeSelectionBounds();
> > > if (bounds == null)
> > > return;
> > > OLMap.zoomToExtent(bounds);
> > > Thanks in advance!
> > > Regards,
> > > Dmitri
> > > Gruß,
> > > Dmitri
> > > _______________________________________________
> > > Users mailing list
> > > Users at openlayers.org
> > > http://openlayers.org/mailman/listinfo/users
> > Users mailing list
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070706/ff011492/attachment.html
