[OpenLayers-Users] OpenLayers, Google Maps, and WFS example
Erik Uzureau
erik.uzureau at metacarta.com
Mon Jul 9 17:31:05 EDT 2007
Justin, sounds like you have been hard at work.
The map resizing issues is still unfortunately a murky area with OL.
If you would like to share your patch with us, it would be well appreciated.
http://trac.openlayers.org/wiki/HowToContribute
erik
On 7/9/07, justin merz <jrmerz at gmail.com> wrote:
> I am sorry if this has already been done/covered, but I have been in the
> processes of developing some online apps using OL and Google layers. I have
> version of OL (using ESPG 41001) up and running with the Google Layers
> here...
> http://team.resources.ca.gov/justin/lightweight_viewer.aspx
> Issues I ran into and seem to have a fix for (or at least a working hack):
> -> WFS overlay not fitting/floating (depending on pan/zoom). This was done
> by using doing projection conversions in
> getLongitudeFromMapObjectLonLat,
> getLatitudeFromMapObjectLonLat, and getMapObjectLonLatFromLonLat in
> OpenLayers.Layer.Google. As well as defining new extents and zoom levels.
> -> Google Layers moving center position upon a layer switch, after the
> map/browser has been resized. This I have not totally figured this out, but
> the OL view plane and Google view plane seem to be off. I fixed this with a
> hack in setMapObjectCenter in Google.js. Basically I set center, tell the
> google API to see if the map size has changed, then set center again.
> -> Other: I have also added a very quick and dirty "loading …" display for
> WFS and a WFS feature selector that allows for quick display of other
> information inside GML. These use outside div's and have not yet been
> migrated into OL. Also on a browser note, I made two different classes for
> vector rendering styles, one for IE and one for everything else.
> -Justin Merz
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
