[OpenLayers-Users] Does OpenLayers support orientation of
points?
Robert Jeansoulin
Robert.Jeansoulin at univ-mlv.fr
Thu Jul 12 05:51:00 EDT 2007
- About this " orientation of points " discussion thread:
I do believe that any " Geometry " or " Feature " can possibly be attributed
an orientation, not only Points.
A LineString, a Polygon, even a MultiPolygon may be characterized by a
" general orientation ".
Actually, a good approximation of any spatial object could be an ellipse
(the kind of potato we can sketch on a map) for which we need a LatLon
plus two floats.
Let's name Potatoid this ellipse.
Hence, I would be interested by a more general solution, and I have a
suggestion :
Tim proposes to use OpenLayers.Feature.Vector
that associates external attributes to a Geometry, it is one point ;
the second point is that there is a method
Geometry.atPoint(lonlat, toleranceLon, toleranceLat)
that positions approximately the Geometry,
it is - as I understand - simply the center of the bounding box
hence, for a Point, it should be the Point itself (I didn't check)
but the other two parameters can be used to determine the orientation,
and for Point, they are certanly zero (I didn't check)
therefore, the Potatoid, or ellipse, or oriented point, etc. can be
set and drawn
from the answer of
Geometry.atPoint(lonlat, tlon, tlat)
or OpenLayers.Feature.Vector.Geometry.atPoint(lonlat, tlon, tlat)
The problem is : how to set these (lonlat, tlon, tlat)
differently that from the bounding box ?
my suggestion is that the method atPoint should exist also at the
Vector level, and:
- to add methods :
Vector.setPoint(latlon)
Vector.setOrientation( tlon, tlat) e.g.: sinAlpha, cosAlpha
in case we want to explicitely set the Potatoid
It can be set in the Vector.attributes object, but we need a special flag
to inform the atPoint() method to behave differently in this case :
- Vector.Geometry.atPoint() is exactly Geometry.atPoint()
if the flag is false
- Vector.Geometry.atPoint() returns (lonlat, tlon, tlat) computed from the
Vector.attributes, considered as the Potatoid, if the flag is true
That it makes sense ?
Merci,
Robert.
Robert JEANSOULIN
PhD, Ing., DR CNRS, Assoc.Prof. U.Laval
Labo.Informatique - Institut Gaspard Monge
Universite Paris-Est
77454 - MARNE-LA-VALLEE Cedex - France
RER stop: " Noisy-Champs " (line A)
Tel.: +33 (0)1 60 95 77 26
Fax: +33 (0)1 60 95 77 55
www: http://igm.univ-mlv.fr/~jeansoul/
