[OpenLayers-Users] Problem with zoomexents and google maps la yer
Stephen Woodbridge woodbri at swoodbridge.com
Sat Jul 14 13:47:03 EDT 2007
John,
Thank you I will see that we give that a try if we are not already doing
it. I was posting the original inquiry for Les Szklanny that is doing
the development. At the moment the problem is in an OL integrated with
Slippymap.com application so it is possibly not an OL problem at all.
I'll ask Les to try the above suggestion and to provide a follow up
example in just OL if he can demonstrate that.
We really appreciate all the development and support we get from the OL
community.
Thanks,
   -Steve
John Cole wrote:
> Steve,
>   You might be doing this already or it might not apply, but...
>   If you are using zoom levels (and not just free zoom scales) find out the
> zoom level for your extent with something like:
> var zoomlevel = map.getZoomForExtent(ci.Bounds);
>   This should make sure that your entire extent is in the view port.  Then
> use a setCenter with the center of your bounds and the zoomlevel.
>   Like I said, this might not apply in your case.
> John
> -----Original Message-----
> From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On
> Behalf Of Stephen Woodbridge
> Sent: Friday, July 13, 2007 4:44 PM
> To: openlayers user list
> Subject: [OpenLayers-Users] Problem with zoomexents and google maps layer
> Hi all,
> I have run into an annoying issue that if you zoom to an extents the
> extents is not always inside the viewport, so if I have a bunch of
> points and zoom to their extents, sometimes some of the points are
> outside the viewport after the zoom.
> Is there a fix or workaround for this problem?
> Thanks,
>    -Steve W
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
