[OpenLayers-Users] Problem with GML coordinates?
Christopher Schmidt
crschmidt at metacarta.com
Mon Jul 16 18:41:58 EDT 2007
On Mon, Jul 16, 2007 at 05:16:32PM -0500, Jeff Dege wrote:
> I think that's the problem. It's assuming that if it uses
> gml:coordinates, it's GML2, and if it's using gml:pos or gml:posList,
> it's GML3, and that if it's GML2, it only has two dimensions.
> Now I'm not sure whether ogr is incorrect in using three dimensions in a
> gml:coordinates element, or whether the GML format class is incorrect in
> assuming that the lack of gml:pos or gml:posList indicates two
> dimensions. But if it's a bug in OGR, it's going to be a widespread
> one.
> > Can you
> > put up a full GML file generated by ogr2ogr in this way so that it can
> > be examined by developers who might be able to improve the parser to
> > handle this case?
> I'm using the ogr2ogr bundled in MS4W version 2.0 - which seems to be
> gdal/ogr version 1.3.2.
> I've attached the input and output files, and copied the email to you
> since I'm not sure the list will accept the attachments.
Great. This is clearly a bug, and should be fixed in the Format.GML
class.
Erik, can you file a ticket for this, marked for 2.5, and attach the
output file to the ticket as an attachment so we don't lose it? That way
I'll have the data to test against when I'm fixing it.
Jeff, I assume you don't mind if we use the GML data in question as data
for our unit tests?
Regards,
Christopher Schmidt
MetaCarta
