[OpenLayers-Users] DOTS_PER_INCH -> PIXEL_PER_INCH
Benoit PESTY tchule at hotmail.com
Wed Jul 18 03:48:12 EDT 2007
Hello,
Just a little note from a guy who seems to have nothing better to do (but
should).
I was working with resolutions and scales and tilecache and I was trying to
adjust everything to have a set of predefined levels corresponding to fixed
scales (1 : 1M, 1 : 500 K, ...).
I seems that in fact it's better to works with resolutions instead of scales
when using tilecache and that the base extend should correspond to 2x2 tiles
at the max resolution.
I have a TIFF file in 3200 meters per pixel, I've had to adjust my EXTEND so
that it correspond to 3200*512 to avoid rounding problems and missing tiles.
Now, the scale controller show a scale based on the following calculus :
3200 pixels/meter * 72 ppi * 39.3701 inch/m -->  1 : 9 M
The 72 ppi and 39.3701 inch/m values are defined in the Utils.js
72 ppi is the same value used by Mapserver by default.
I've made a some research on Internet to understand how it works and maybe
we should add a little note on the OpenLayer site.
All this to say that if I understand well, we should rename the variable
"DOTS_PER_INCH" of the Utils.js file into "PIXEL_PER_INCH" to be more
correct (I know, I should have done more important things this morning ^^) .
http://www.scantips.com/no72dpi.html
http://en.wikipedia.org/wiki/Pixels_per_inch
http://en.wikipedia.org/wiki/Dots_per_inch
Tchule.
_________________________________________________________________
http://imagine-windowslive.com/hotmail/?locale=en-us&ocid=TXT_TAGHM_migration_HM_mini_2G_0507
